Today, I simply cut off all the tubing from the part that bolts to the heads. I then swapped them on the opposite sides with a little RTV on it, and bolted them back up backwards. Easy as pie!
You don't need a size to use "miley_stang"s method. Use use the bolts already there. You are flipping over the hollow caps which are flat on the back and using them as block offs. So you bolt them on, just like they were. You don't have to buy anything.
