what top end kit for a 347ci?
if i go with a 306 i know i'm going with the trick flow kit good for
350hp and 370f lbs of tq
however if i go with a 347 or 331 what heads and intake and cam wouud you guys sugg.
oh one more thing it need to be boost frendly as i might later add a turbo or cent. blower
Well if you are wanting a kit, the Trickflow set isn't to bad. It is typically set aside for 302/306's. You could expect 340-350rwhp, but of course there is so many variables that determine actual output to the tire and how aggressive you want the set-up.
If I had to put a combination together for a 347:
AFR 205's, Custom Cam, Systemax Intake, 1 3/4" headers (with cam to match), 80mm MAF, 70mm TB.
For a 331 I'd do AFR 185, or Canfield 195, Custom Cam, Systemax Intake, 1 3/4" headers (with cam to match), 80mm MAF, 70mm TB.
