Due to the differences in overall weight, weight bias, unsprung weight, springs, tires, road conditions, driver perspective, etc., I don't see a post here that is wrong.
Shocks should be chosen or adjusted to meet the specifics of the car, condition, and driver preferences. Even the same shocks on the same car can feel different to different drivers.
On the '66 in the signature below, it started off with Gas-a-just all the way around. But this car has much less unsprung weight than stock, and the suspension is pretty tight even with the stock springs. The result was a rear end that was so sketchy, the car would snap swap on rough corners. That's a very scary situation with no roll bar and 40 year old seatbelts. Opting to try something cheap, I tossed a set of GR2s on the rear, and it was a huge difference. However, after about a half hour of agressive driving through rough twisty corners, the shocks fade noticably. On smooth roads, at reasonable speeds, I doubt they would fade enough to be noticable.
I've got a nice set of 5 way adjustable Tokico Illuminas to go on this car later on after it's back on the road.
