Im sure alot of you know about the turbo kit i built in the last 6 weeks.
Well i had it running and making boost ( 15psi +)
I knew the motor wasnt going to last, since i had a broken ring land before i even put the turbo on.. Broke it from the Vortech, on a crap tune.
Needless to say after a few 15+ psi passes on pump gas, down the local highway, I blew a head gasket to hell, and of coarse blew a TON of oil all over, from all the blow by, caused by the broken piston.
But let me tell ya.. It was insane on 15psi. Stayed pretty striaght to my surprise, and really frekin got down a moved.
Plan is... built up the sportsman block i have sitting in the garage to a 306.. good crank, rods, bolts, pistons.. use some head studs ( 1/2") and some good HG's this time. Should be back in running shorty. Ide give it less then a month.
