Whats next!?!?!?!
fiveohGT
353
Fairfax Virginia
okay im just about to order the trick flow track heat kit. Should i go with a stage 1 or 2 cam?
What else do I need to support this kit? Throttle body/egr, 76mm Mass Air, what # injectors, and what LPH fuel pump? Anything else!? Thanks a lot and I am so excited!
-Steve
I'm pretty sure the stage 2 wont clear the stock pistons. so if you want to notch them some more you can. just take like a die grinder or a dremel to em.
255lph pump
76 c&l mass air w/elbow
24's or 30's
a AFPR if you don't have one (Kirban)
whatever brand tb you want
i'd probably go with 70 or 75mm, if you plan on getting turbo, s/c later on go with 75.
i still run stock tb/egr myself, not a huge power difference, but a definite throttle response.
Pro M might have some chrome style maf's, but i prefer c&L.
