- Apr 16, 2004
- 324
- 2
- 19
I was going down I95N cruising at about 70, when I heard a loud popping niose..sounded like a backfire..I looked and I had oil pressure, but the engine sputtered and turned off. I coasted to the side of the rd, and tried to crank it again. The car backfired loudly, and did not crank. It then sounded as if it was trying hard to turn over, like something was blocking it..I went under the hood, no leaks, oil. water, ect, I tried again and it sounded as if it would crank and again a very loud backfire. I towed it home.
Today I took a good look and I did not see anything..someone a spoke with said it sounded like the distrubuter coil ?? Um I am a bit noob to this, so A: what does it sound like to you guys..and B: The distruber coil is where...The cap and rotor, or the shaft they go on ??
HELP
HELP
So do I just go with a head set, 'The ones that include everything' or just drop in a new engine ?? Need some advice on this, as I have just step out of the circle of my limited knowledge.
