Wheel narrowing. Cost and question
  • Thread starter Thread starter Daggar
  • Start date Start date Dec 14, 2005
D
Daggar
3,902
  • Dec 14, 2005
I'm looking to get a set of steel wheels narrowed. They're 15 x 10 with a 5.5 inch backspace. I'd like to get on inch cut out of the outter lip to make them 15x9 with 6.5 in BS.
Two questions:
Does anyone know what this would cost?
By trimming 1 inch out of the outside of this thing, am I truly making the backspace 6.5? What I mean is... it's still going to be 5.5 inches from the inside lip. Is backspacing calculated from edge to edge on the wheel or is it just a measurement from the inside lip to the hub?
Thanks,
Daggs
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Dec 14, 2005
  • Dec 14, 2005
Backspace is the distance from the hub mounting face to the inside rim. Cutting an inch out of the OUTER rim won't change the backspace. You'll have to cut the width out of the IN BETWEEN the mounting face and INNER rim if you want to reduce the backspace.
Cost? You'll have to ask the companies that do it. Those kinds of mods aren't done very often. In my opinion you'd be MUCH better off buying a MUCH lighter aluminum wheel that has the width and backspace you desire.
D
Daggar
3,902
  • Dec 14, 2005
You've got a PM Mike.
352Ford2
393
Seattle,WA
Dec 14, 2005
  • Dec 14, 2005
stockton wheel does it, what they do is cut the center out and put it on a new out piece, its pretty expensive, but good for those times you want factory wheels for stealth.
most good wheel shops can do it (there are usaly a couple around big citys)
http://www.stocktonwheel.com/
P
PRO50SC
1,012
Olney, Maryland
Dec 14, 2005
  • Dec 14, 2005
http://www.weldcraftwheels.com/
Quoted me $125.00/wheel plus shipping if I recall correctly.
I contacted stockton as well ans they told me they didn't narrow wheels anymore. Don't know how accurate it was but.....
D
Daggar
3,902
  • Dec 14, 2005
Thanks for the links guys. I'll be checking with both of those vendors to see if they can either modify to fit or even custom make the wheels that I'm looking for. You've given me another avenue to persue!
HISSIN50
34
129
Dec 15, 2005
  • Dec 15, 2005
Andy, I think the place Bernie linked to did some work for a 94-95 owner and he posted a thread about the experience with pics.
EDIT, here is the thread (obviously for widening, but you can see the welding):
http://forums.stangnet.com/showthread.php?t=365894
Good luck bud.
P
PRO50SC
1,012
Olney, Maryland
Dec 15, 2005
  • Dec 15, 2005
Good luck bud.
:Word: Good find detective LOL! That's the thread I first found out about Weldcraft. I plan on narrowing my front bullits by 3 inches when extra money allows.
Rick 91GT
Mustang Master
95
99
PA
Dec 15, 2005
  • Dec 15, 2005
Just mini tub it, cut the axles down and go with a 12" wide wheel
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Height of wheel well opening over the tires, front and rear, and adding clearance for 17x9 wheels up front
  • Blue Thunder
  • May 21, 2024
1974 - 1978 Mustang II Talk & Tech May 21, 2024
LILCBRA
M
Need Wheel Measurement Help Please
  • MintyFresh
  • Nov 15, 2022
1965 - 1973 Classic Mustangs -General/Talk- Nov 16, 2022
manicmechanic007
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
