Wheel Rub...Eibach Pro Kit
  • Thread starter Thread starter Auto Reverse
  • Start date Start date May 13, 2005
Auto Reverse
265
Buffalo, NY
May 13, 2005
  • May 13, 2005
I had a passenger for the first time since having my Eibach Pro Kit installed. I wiegh about 185, he weighs about 215 and there was a little wheel rub on the right rear tire.
Is a little rubbing normal once you lower the car?
The car looks dmn awesome though.
Auto Reverse
265
Buffalo, NY
May 13, 2005
  • May 13, 2005
Anyone!
302GT
81
Carson City,Nv.
May 13, 2005
  • May 13, 2005
What size wheel do you have?Mine did that with the cut springs.I had 235/55/17's on the back.
Auto Reverse
265
Buffalo, NY
May 13, 2005
  • May 13, 2005
I'm running 245/45/17 Nitto DR's out back.
302GT
81
Carson City,Nv.
May 13, 2005
  • May 13, 2005
Can you see where it was rubbing?Mine was hitting right at the top of the ground effects.
jb89coupe
416
CT
May 13, 2005
  • May 13, 2005
Wow, with my pro kits I have enough room to stick 4 fingers between the top of the rear wheels and my fender lip, but then again I have a coupe. Check to see if its rubbing on the inside or the outside.. I had 245/45/17's all around and only rubbed the fronts on full turn. What size/offset wheels do you have (not tires)?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
May 13, 2005
  • May 13, 2005
I'd suggest looking at your shocks and seeing if they need replaced. Ride height isnt just the springs, it's also the shocks. I've had 245/45/17 Cobra Rs on my car all the way around and none of them rubbed, and i've even got stock shocks on mine but i had no rubbing issues. Do you have some kind of oddball back spacing on your rims?
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
May 13, 2005
  • May 13, 2005
I'd also check your spring install. If you have the pigtails on the rear 180 degrees out then it will drop the car a lot more. Also, do you have insulators on the springs? Seems like the problem is with the springs/install and not the tires. How much tire clearance did you have prior to the install, I assume with stock springs?
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
May 13, 2005
  • May 13, 2005
Also, where is the rubbing? If it rubs on the inside against the quad then I would say that is somewhat normal.
Auto Reverse
265
Buffalo, NY
May 13, 2005
#10
  • May 13, 2005
  • #10
Okay, I should've also mentioned that I just reaplaced my brakes too. It was the metallic pad wearing in. It's actually starting to go away the more I dirve. Later. Damn I love those Eibach's though!
tunedin302
I AM the law!!!
Jul 29, 2004
1,251
Pennsylvania
May 13, 2005
#11
  • May 13, 2005
  • #11
:damnit: but glad you figured it out.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
D
Will 2023 (Non-Handling Pack) Mach 1 Wheels Fit A 2013 Mustang GT OK?
  • dmw_4814
  • Oct 27, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech Oct 27, 2026
dmw_4814
D
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
