Wheel & Tire Combos - list yours here:
of course it is. here's the original pic, it's ours.
just purchased 19" for my car i really wanted to get 20" but did not want to give up a fatter tire......please advise me on some nice rubber "FAT RUBBER NICE SIDEWALL" (EVEN BETWEEN FRONT AND REAR TIRES) and the widest possible....thanks
specs
19x8.5
19x10.5
thanks for your help:SNSign:
specs
19x8.5
19x10.5
check out this STICKY thread here in GT tech....
http://forums.stangnet.com/showthread.php?t=607768
gp001 said:
Wheels:
Brand - ROH
Model - Drift R Black
Wheel - Diameter Front 19x9, Rear 19x10
Offset - Front +35mm, Rear +45mm
Did you need/use a spacer? No
Tires:
Brand - BF Goodrich
Model - KDW 2
Size - Front 275/40-19, 295/35-19
Suspension Mods if any
Eiback Pro Kit
BMR Adjustable Panhard
BMR Adjustale LCAs
click here for a pic of his car.....
http://forums.stangnet.com/showpost.php?p=5022239&postcount=1
Are these the same SSR GT-10's?
delurker said:
SSR GT-10's with BFG KDW-2's
Front: 18x8 +49mm offset, 255/45/18
Rear: 18x9.5 +43 offset, 285/40/18
Yours are really shiny. These rims I attached look kind of flat. They are noted as being
Hand-painted with polished outer rim and clearcoat
Finish: Silver w/Machined Lip
Are they the same as yours? They are from a BMW M3 E46 and I'm hoping I can slip them onto my 05 Mustang GTwithout any mounting conversion. Thanks!
question for anyone with aftermarket wheels that maybe can answer my question..............normally when purchasing staggered wheels meaning
(19x9......19x10)......normally i see people using a tire setup the have different sidewall heights like 245-(45)-19 front and 275-(40)-19 i guess to even the height of the sidewall out between front and rear tires? (correct?)
so how come for instance on saleen equipped cars the wheels do not follow the same kind of setup, like on the parnelli car it uses a 19x9 19x10 wheels
but the tires are
front : 275x40x19
Rear : 285x40x19
:shrug:
the thing is, the tires look even in sidewall height on the saleen:shrug:
as well as cars with the staggered tire setup?............i dont get it????:bang:
but the tires are
front : 275x40x19
Rear : 285x40x19
:shrug:
in a 275/40/17 tire, the tread is 275mm, but the sidewall aspect ratio is 40. this means that a 40 series tire is not the same height for all 17" wheels. 275 and 285 width tires are very close in width, so the same sidewall aspect ratio would make for a very similar height. the difference is so small that it is unnoticable. if you look at a tire manufacturers specs, it will list the overall diameter of various size tires. the diameter might be off .10" this difference is so small, that the tires are usually considered the same diameter.
hope that explains it a little better for you. if not, let me know. :nice:
The ones in your pic look similar, but I can't tell if they're the same from so far away. Here are a couple of pages of pics of mine, though. They're definitely more shiny than the pic of just the rim above my car in the earlier posts.
One page
Another page
2KO5gt
Those are the best looking wheels for the 05+:nice:
I have them on order right now - 18x9 deep dish anthracite bullitts with 255/45/18 tires. They must make your car look lower because I don't see suspension mods in your sig yet the rear end looks lower than stock.
245/40/20 up front and 275/35/20 out back on Foose Nitrous Rims. I think I need to lower my car about 1" to 1 1/2" inches.
