When to tub?
5.0 MPG
Ausitn. TX
I have a 91 that I am about to convert to 5 lug. Here is my question with an 18" rim all around and 10" wide on the back and 9" on the front do I have to do any other modifications? I want to try and avoid tubbing out the wells.
Can I go to a 18" and how wide? Im sure someone else has had the same delema. I dont want to go bigger than 18". It starts looking silly after that. 18 is nice but I would like to go as wide as possible. Give me some feedback guys.
Jesse
I have 18x9 Cobra Rs with 235/40ZR18 Nitto NT555s (no modifications) and I have no rubbing except for a tiny scrape on the sway bar at full lock. File down the sway bar and you're in business. I've heard of running 275s out back just by removing the quad shock, so your combo should probably be like this:
Front - 235/40ZR18
Rear - 255/35ZR18
Stick with 18x9s all around.
Only tub a car when you are no longer going to drive it on the street.
Tubbing can require cutting the unibody and then reinforcing the rear structure to restore strength and rigidity to the frame/body. Do it wrong and you severely weaken the car’s structural integrity and handling characteristics.
....and a small rub at full lock on the sway bar won't hurt a thing. You can only be going at a very low speed at full lock anyway. You don't want to cut or file on the sway bar -- nothing that might compromise it's structural integrity.
Also, 5.0 MPG - you keep talking about 18's -- but you don't tell us what size tire you intend to run. Overall diameter of the tire is a key variable in proper fitment.
No point in tubbing a fox, people run in the 7's and 8's untubbed.
From a cosmetic and traction standpoint, 1 inch wider of a rim will mean nearly nothing.
So just use a 9 inch wide rim and be happy.
I use a 275/35/18 bfg drag radial, and i couldn't be happier.
Tire physcially measures 10 inches wide.
onefstsnake if you're referring to the blue lx hatch Bert306, he runs both quadshocks and tailpipes. i do not believe he rolled his fenders either, but i could be wrong.
