When was my engine made?
Redfire 05
236
Lubbock, TX
Is there a serial number on the engine, and heads that has the build dates? I have an 86' GT, but I suspect a later model engine may be in my car. I already know the tranny is a 90-93 model AOD. I suspect maybe the previous owners found a wrecked donar car and swaped the drivetrain out. I am hoping they did, because I want to get a set of aftermarket heads, but an 86' engine with flat top pistons complicates matters. How do I tell? I noticed that the oil pan has two drain plugs, I thought only later model 5.0s had this.
You can find the year of the engine block by looking at the casting numbers, but that does not mean that it has stock pistons in it. I would suggest pulling the heads to check for sure. It is a pain to do all that work just for some info, but that is the only way I can think of to know for sure. The block casting numbers are on the underside in the rear. Cant remember which side, but I am fairly sure they are hidden by the headers? maybe someone else should try to answer that.
Redfire 05 said:
Thanks, I'll take a look. So how do I decode the casting number? Is there a website that explains it?
First 2 digits are the important part.
The first digit is a letter and indicates the decade of the casting.
C 60s
D 70s
E 80s
F 90s
The second digit is the year in the decade.
C9...=1969
E7...=1987
This is true for most all Ford parts of our era.
