Boo Boo Foo
- Jul 1, 2004
- 26
- 0
- 0
Yep, that's exactly what I'm saying and thank you for proving my point (albeit unknowingly).DarkBuddha said:You're making a huge assumption that it is necessary for the fluid to remain in the radiator the same amount of time or longer in order to dissipate more heat than it can absorb in the block.
Exactly. Remember the two pivotal factors involved in the physics of heat exchange - initial temperature difference, and length of exposure. The FLAW in your logic is that the engine block is NEVER going to cool down while there's still fuel burning. Hence, the goal of the coolant system is to avoid stagnation within the block. Yes, cast iron retains immense heat while aluminum cools quickly - but that has little to do with coolant per se. The coolant is merely the conductive device needed to transfer that heat between the engine block and the radiator. The quicker the coolant can get from the block to the radiator the better, not the other way around.DarkBuddha said:As I mentioned before, you have to consider the types of materials involved in the heat exchanges. Aluminum and copper are better conductors of heat than iron, therefore the coolant can dissipate more heat quicker than than it collects in the block.
The thing that counts here is that the engine block is essentially a furnace, that is, it ain't gonna stop trying to melt until the fuel stops burning. Hence, the goal of the coolant system is to offset the melting process (aka overheating). By extension, the coolant system is a bleeding system - it's role is to provide a constant source of energy escape. And THAT is the flaw in the theory of "dwell time"... if you allow coolant to stay in the engine block for too long under high workload, the coolant gains in temperature and in doing so, reduces it's ability to act as a heat sink.
The slowness of iron to radiate heat is also it's worst enemy in an overheating situation - that is, it also reflects the ability of iron to retain heat as well. Ergo, the goal is LOTS of coolant, and the lower the temperature of that coolant, the greater the benefits. Ironically, by trying to argue with physics, you've actually proven my point. The issue regarding a thermostat in the context of THIS particular thread relates to the role it plays - and my position is this... a thermostat's job is NOT to prevent overheating, rather, it is to prevent overcooling by arbitrarily imposing restriction into the coolant flow. In short, the only way an engine can overheat without a thermostat in place is because the coolant system is flawed to begin with. That's my point here. People keep mixing up the two systems - the goal of coolant system is to prevent overheating. The goal of a thermostat is to prevent overcooling. It's impossible for the latter to affect the former if the former is working functionally.
And THAT, right there, is rubbish. The coolant/block membrane is where the heat transfer takes place, and the longer the coolant stays still, the greater it heats up, and by extension, the less it does it's job. Ergo, the block overheats. The role of the coolant system is to provide a heat sink, a constant bleed of energy. This is achieved by providing LOTS of cool water, and then moving it on as quickly as possible so that MORE cool water meets the heat exchange membrane. The moment you introduce coolant stagnation into a fully warmed up internal combustion engine, you introduce overheating issues - period. Coolness and Flowrate are the goals.DarkBuddha said:In fact, since iron is a poorer conductor of heat than aluminum (or copper), then the coolant could spend approximately 3x the amount of time in the block than would be necessary for it to cool in the radiator.
Of course, it's possible to OVERCOOL an engine by introducing too much coolant and flowrate. Hence, a thermostat modulates that latter problem.
