Where can I find a TPS voltage
markavalenti
Bend, OR
I am going to be installing a LM-1 A/F ratio computer with the rpm converter, and I would like to know where the best/easiest place to tap into the TPS sensor for a voltage signal is. I know I can go directly to the TB, but I was wondering if anbody knew where inside the car I can go, I also have an Anderson PMS, I don't know if it has an output for this? Any help would be great. Thanks.
Follow this diagram. The computer lives under the passenger side kick panel.
Do your wiring there rather than in the engine compartment.
See http://fordfuelinjection.com/?p=7 for the proper method to splice any
wiring that you do.
See the following website for some help from Tmoss (diagram designer) & Stang&2
Birds (website host) for help on 88-95 wiring
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
