  • SN95 4.6L Mustang Tech
where da hell is
  • Thread starter Thread starter jdarius
  • Start date Start date Jun 16, 2010
J
jdarius
  • Jun 16, 2010
where that heck is the fuel pump relay. i have a 1996 gt vert. i cant find the fuel pump relay. ive looked in the trunk, all over the engine compartment and also on the passenger side front fenderwall. and dont see anything. im beggining to think they it was removed and never put back from the last owners. and the dam book dont say jack on where its at.helllpppp
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 16, 2010
  • Jun 16, 2010
Starting in 1994, Ford put it inside of the CCRM (constant control relay module). Unfortunately, the CCRM is not a servicable item and would need replacement if the relay is indeed bad.
M
mr-mike
122
  • Jun 17, 2010
I have a 99 gt the fuel pump relay is inside the pass side fender you can see it with a light , a little tricky to get at , I thought mine was bad turned out it was the pump so check it out well ...good luck
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jun 17, 2010
  • Jun 17, 2010
The CCRM (Constant Control Relay Module) is inside the passenger side fenderwell. It has the fuel pump relay, AC relays and fan relay. Pretty much you will change the whole module if that is your issue. You have to remove the fenderwell splash guard to get to it.
What is the problem you are having?
96 mustang gt
  • 96projectgt
  • May 2, 2025
  • 2 3
2K
1996 - 2004 SN95 Mustang -General/Talk- May 15, 2025
96projectgt
9
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Wednesday at 4:28 AM
2v_johnny
J
2000 Ford Mustang GT No Crank No Start please help
  • Jowen216
  • Jun 5, 2024
3K
SN95 4.6L Mustang Tech Jul 5, 2024
Jowen216
J
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
