Where do I start?
  • Thread starter Thread starter 9150lxct
  • Start date Start date Jun 7, 2004
9
9150lxct
CT
Jun 7, 2004
  • Jun 7, 2004
I am new to the forums. I have owned Diesels since '92. I am looking for guidance on what to do to my 5.0.
91 5.0 LX Notch Back
AOD Tranny
2.73 Gears
KN stock air box filter
Dual Flow Masters
Where to start??
Thanks in advance.
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Jun 7, 2004
  • Jun 7, 2004
swap out the gears for either 3.73's or 4.10's
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 7, 2004
  • Jun 7, 2004
do a search for what to do first and youll get about 1000 threads that will tell you what to do. not tryin to be a dick about it, but a lot of people wont even look at this thread or reply to it because theyve seen it a million times. im not one of those people....so first thing i would say would be to get some subframe connectors (full length from maximum motorsports or other company) get some 4.10 gears if you dont mind high revving on the highway, lower control arms, and some lowering springs. that should give you a good base to start modding the motor and getting the power to the ground.
Stang8URMPRT
1,100
Daytona Beach, FL
Jun 7, 2004
  • Jun 7, 2004
ECU5.0 said:
do a search for what to do first and youll get about 1000 threads that will tell you what to do. not tryin to be a dick about it, but a lot of people wont even look at this thread or reply to it because theyve seen it a million times. im not one of those people....so first thing i would say would be to get some subframe connectors (full length from maximum motorsports or other company) get some 4.10 gears if you dont mind high revving on the highway, lower control arms, and some lowering springs, short throw shifter, firewall adjuster, and aftermarket quadrant. that should give you a good base to start modding the motor and getting the power to the ground.
Considering he has an AOD, I don't think the short throw shifter, quardrent, or firewall adjuster will help him much.
I would definatly go with 4.10s. Get a SHIFT KIT for that car. A shift kit will not only improve performance, but it will also extend the life of the trans because it increases line pressure which doesn't let the clutchs slip, the number one thing the goes bad in an AOD. Then I would put under drive pulleys. They are the best bang for the buck part. Save header, and throttle body and MAF until you get more balls. They won't help much on a stock motor. Do an oil change, and do a basic tune up... Good wires, good plugs, good cap and rotor. A torque converter will also wake up the AOD, get a 2000-2500 RPM stall. Hope this helps.
Nick
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jun 7, 2004
  • Jun 7, 2004
Nick
haha, youre right about that man. i definetly went back and added that in after i got done typing too...guess i forgot he had an aod by the time i got done. and i agree about the stall converter and shift kit.
68 vert where to start?
  • 67 blueberry
  • Jul 2, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 2, 2026
67 blueberry
  • Locked
93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 28, 2025
Progress Thread 93 LX father son project
  • ZAM93LX
  • Oct 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 3, 2025
Scrapla347
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
D
SN95 V6 1994 occasional rpm surge while driving---where should I start?
  • DPP
  • Aug 30, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 5, 2026
DPP
D
