I think my clutch cable/quadrent are shot.. i cant adjust it anymore by pulling the pedal up.. I do have a new cable and adj quadrent in my garage, just never had the time to put it in
Sould it engage/disengage, HIGH up the pedal?? or close to the floor.. My pedal sags with alot of play and engages/disengages near the floor.. the pdeal doesnt have that far of travel like any other stang i drive... Sometimes on a hard 1st to 2nd shift, i will grind it.. Would a bad cable give me my problems?.. the trans i bought rebuilt with a 6 month warrenty and i hope its not the syncros.... 1st to second IS usually a smooth shift.. doesnt pop out or anything... Just sometimes when i shift hard, it will grind
The last thing you mignt need to know is that when installing the new adjustable clutch cable you might need to cut some of the adjustable end depending on how you adjust it so that the cover can be bolted back on. On my car though the majority of the slack in the cable is taken up with the firewall adjuster. Good luck
