Where is my 300RWHP Pull?
90LX306
433
Warren, R.I.
Hey guys, i have not been around latly but i am now searching around again and started to notice i didnt make as mush power as i should have. About a month ago, my car made 294.77RWHP and 313.83 RWTQ on a DynoJet dyno. Considering last year my car had e-brock heads, TFS Street Intake,and a Comp XE274 cam it made 285 rw, i only gained around 10 rw this year. I seep headed combo's making about my power so im starting to think im loosing something somewhere. Here is my entire combo: 306 balanced, romac damper, Eagle i beams, JE/Srp pistons, AFR 185's w/spring upgrade, titanium retainers, TFS Stage 1 cam,Harland Sharp 1.6 rr, TFS Track heat intake w/1" spacer,24lb injectors, 75mm Pro-M, 70mm BBK tb, C&L Trueflow pipe, K&N Panle in stock box, Mac 1 3/4 LT into a Dr.Gas 2.5" X pipe, Flowmaster cat back, 155lph fuel pump.
The car was dyno'd without the air box and made no additional power. I know the 185's r overkill on my 306 but forced induction is in the future. I personally think i should have atleast 305-310 Rear wheel, can anyone think of something that might be holding my car back? Thanks in Advance guys.
The key to any setup is the tune.. How does your fuel curve look on the dyno? A Tweecer may work wonders!!
Auto or 5sp? auto's lose a lot more power to rear wheels (meybe not that much.. but it could be a factor)
You have a lot of nice stuff. Unfortunately, your heads are a little big- but you know that. The big problem is the broomstick you're using for camshaft. Those heads deserve better. Your exhaust [headers] is murdering you as well. With a power adder and a cam you'll do great. BTW- auto or stick? Compression?
Well, you really didn't match your combo well. The AFR 185 and Track Heat are more suited for a bigger engine such as a built 347 or a 351W. And why did you spend all the money on those two when you have the TFS Stage 1???? You really should have spent more time selecting the cam.
Ok thank's for the replies...The TFS stage 1 is in there due to the fact i live in rhode island and am required to do emissions testing. I have sitting on the shelf in my gerage a Comp XE274 w/a 555/565 lift that i am debating on throwing back in.2nd, the track heat upper is there because last year the street upper's runners were a little too long so i swapped uppers w/someone else. The car is a stick (stock t-5 which is about to burst) and if i remember correctly it is a 9:5 compression ratio. Everyone i talked to said the 185's wouldnt hurt me that bad, and i dont need to go and buy heads 2-3 times just because i wanted to make crazy power while n/a. Again, the deal w/the cam was that i needed emissions friendly and i got my sticker, you guys think a hotter cam will really wake it up? Thanks again for the reply's. Also...A?F ratio was in between 12 and 13 .
Don't know if this helps or dissapoints you but here it is.....
In MM&FF cylinder head shootout they dynoed a 306 with a Comp Cams XE264HR cam (.512 lift, a dual duration split of 212/218 at .50 ground on a 144-degree lobe seperation angle), Probe flat-top pistons, RPM air gap intake, AFR 165 heads (I can't find the combo they did with the AFR 185's) 34 degrees total timing and got 396HP@5800 and 342TQ@4700 at the flywheel. Average HP 288.89/TQ 353.86, Peak air flow on the flow bench 240cfm Intake and 200cfm Exhaust @.550 lift.
They chose rockers and pushrods for each head tested to find the best combo and I don't have the info handy on those.
90LX306 said:
So did it make 396 Horse? if so then whats the 288 average for? My car currently is not making 396 flywheel horsepower, i think its around 260 i believe.
396 was the peak HP. The average is between 3000 and 6000 rpm, looking at the graph they had around 200HP at 3000 rpm.
That's flywheel HP which would translate to 330ish at the wheels.... but that doesn't matter 1 b/c there were no accessories which can cost around 5-10% of your HP (guessuing) 2 it was fly wheel your figures are rear wheel. Your making around 370ish flywheel hp ... I think the TFS cam has got to go as well try a stage to or throw that comp cam stick back in it.
BTW sounds like the car was a little fat... you could lean it out & try more timing & that would probably put you over 300rwhp as is.
Mike
