EMW150
PURESTREET5006 said:Keep them at .040 that should be good enough and keep you out of misfire.
I agree. I've never seen the benefit of gapping wide. There are alot of things to consider when you gap them other than just the ignition system. The main thing is cylinder pressure. The more you have the tighter you should gap the plugs. This means higher compression or aggressive ramped camshafts that build cylinder pressure. I run mine at .040. I'd say 92Stang302's combo would work well at about .045 /.050 at most.
