I need the harness that connects to the o2's, maf, tfi, etc. This is one whole harness correct? i need the proper name and where i could get one new or refurbished. Thank you
I found a spot that sells them brand new, but I am not at home and can't remember the URL. If no one posts here, I'll be sure to send the link as soon as I make it in the door.
The model year is important, so be sure to check it when you order any parts. The wiring scheme , colors & connectors changed serveral times between 86 & 93.
Copied From bbunt302
Just for reference, here's a list of all the compatible years:
89 harness should work for 86-89 as long as you're using mass air.
90 harness will only work in a 90. (B/c of air bags and dual dash connectors)
91 through early 92 harnesses should be compatible (single dash connector, fuel pump relay under driver's seat)
Late 92 through 93 harnesses should be compatible (single dash connector, fuel pump relay under the hood)
Computers from 89-92 are all the same. Look for the A9L sticker on the back cover for a 5 speed that matches your requirements. Example: E9ZF 12A650 AA" with the A9L code.
Hey not to hijack a thread but where can i got the engine bay harness for an '85? Mine is pretty wore out, starting to get brittle after 21 years of life.....i just need from the main harness that comes through the firewall to the headlights and everything else under the hood.
