Can I just use the subframe connectors to hold up both sides while I replace a midpipe? If so does it matter where on the subframe I place the jacks? Any advice/guidance is appreciated, thanks!
Okay cool, thanks! Just wanted to make sure I wasn't making some totally avoidable mistakeHell yeah. Next to the axles, it's probably the strongest part. Take care to not scuff them all up.
Okay cool, thanks! Just wanted to make sure I wasn't making some totally avoidable mistake![]()
Yes you can. I put my lift pads right under where the SFCs are welded to the cars front and rear subframes and up she goes. Rock solid too, no issues. I installed MM SFCs last month and they are pretty beefy/solid and nice.Can I just use the subframe connectors to hold up both sides while I replace a midpipe? If so does it matter where on the subframe I place the jacks? Any advice/guidance is appreciated, thanks!
That's a bummer, thanks for the tip!I wouldn't jack the car by the connectors themselves. I did some cosmetic damage to my left side MM connector on my 91 GT by trying to jack up the car that way.
I compounded my mistake by using a two-ton floor jack. My intention was to put jack stands in front of the left rear and behind the left front tire so I could rotate tires or something (it was years ago) and I didn't count on the how the weight would be distributed. The rear of the jack itself tilted up and smacked into my left side skirt and damaged it.
