Which Cam For Mild Engine
dcurtis
688
Finished all of the body work I plan to do on my 93GT (cowl hood, saleen wing, cobra r's, and shaved doors) now it's about time to pull the engine and do a basic rebuild on the bottom end and switch the pistons to give me about 9.5 to 1 compression with rebuilt stock heads, new valves, springs etc etc, probably going with the cobra upper and lower intake with??? heres where im not sure.
What would be the best cam for my present combo, the e303, f303,b303, or maybe even the x303, also what size fuel pump, maf, throttle body and injectors would I need for that cam, I would like the cam to good lope to it, but not if it would be to big for the heads and intake, also it does have a t5 tranny if that matters.
Sorry if my question is a little confusing or anything but this is the first ford build I've ever done so I don't know what will work with what, also do the stock 302h.o.'s have 1.5, 1.6 rockers or what? and are the above cams sized with 1.5 or 1.6 rockers
I would say for a nice sound and decent power, and E or B cam woul work well. Throw a set of 1.6 roller rockers on there, 155 fuel pump, 75mm MAF, stock or 24 lb injectors, and a 65 or 70 mm TB and you should be all set!
lol!! and 110 pump and four tires cast iron heads, and make sure you upgrade roller cam though...
seriously e cam would be good if you plan on stil doin more get the b-cam and save the time of doin it twice
Ok I decided to use the trickflow track heat intake instead of the cobra, with a 155lph pump 24lb injectors, 1.6 roller rockers and the b303 cam, do I need the egr intake or not, also does the throttlebody need to have a tps sensor or not, what throttle body and maf would you recommend, sorry but I have no clue to what I need from between the intake to the cold air kit.
Thanks for your help, its really needed
Are you sure you want to just rebuild the stock heads?You could get better flowing aluminum heads or at least upgrade your stock heads (porting etc) for not much more money.If you are staying with stock heads I would recommend the cam you have right now:the stock one,and maybe add 1.7 roller rockers.
my stock heads will be ported and polished, and probably gasket matched to the intake. So, the ford racing cobra intake would be the better choice and I wont need to order an egr spacer or plate? Also, on the B303 camshaft it's rated at .480 lift, is that .480 lift with 1.6 rockers?
yes their all rated at 1.6.
the B cam is less lift more duration than the E, and the E is less duration more lift than the B , i believe they are ground on different lope seperation angles as well which is where the B gets it's lopey ness from...and why the E is smog legal and the B is not..
sounds like everyone has you going in the right direction.. But if you want opinions here i would def get some aftermarket heads....Thats quite a bit of porting that would be done to make stocks flow... As far as cam go's it depends on what you want the motor to do.....Boosted or N/A? My set up is as follows...
306 SLP pistons Stock crank and rods
F- Cam
Aluminum Strike Force heads 2.02/1.60
Trick flow STREET intake manifold 70MM TB
30# inj
1.6 RR
Canton Lower girdle
Now i chose the F cam becuase i plan on boosting the motor..
This cam has great torque around 2000 range for highway but the HP jus feels like it keeps climbing as the RPMs go up... Just my 2 cents for ya...
Goodluck
how do you think the BBK SSI intake would work with the b cam, it also has the egr already there like the cobra intake, I think, plus it comes with a BBk 70mm throttle body calibrated for 24lb injectors and high flow BBk fuel rails.Do you think it would perform better than the cobra intake?
Also, I have been looking for the best place to buy the cam from and I have seen it rated at two differant lifts, one has it as B303, 284 284 duration .480 intake .480 exhaust lift and the other has it marked as 284 284 duration .480 intake .498 exhaust. So which is correct?
Throttle body isnt what you need to calibrate for the injectors, it is the mass air flow.
its 224 224 and 480 480
