How do you figure easier to install? All require the front of the motor to be torn apart and all require a little prayer before, hoping you don't bash out one of the cam bearings.fiveo'cobra said:Steeda 19#, Trick Flow stage 1, FTI are all badass cams for a bolt on cobra, but the 2031 is the easiest install since it was basically designed for a 5.0 cobra engine. To pick one up i would try ebay(longshot) or the classifieds in a stang forum. Fordpower.net, corral.net, superstallions.net, etc are all good places to find one. Or you can go to Summitracing.com and pick up the cam and the valvespring kit up new for around $300 shipped.
Will what still work for GT's?flyboy_323 said:Would these still work for GTs?
Joes95GT said:How do you figure easier to install? All require the front of the motor to be torn apart and all require a little prayer before, hoping you don't bash out one of the cam bearings.
There's no such thing as one cam being "harder" to install then the next in the same motor....
Joe
You could be right, however, I wouldn't use that as a selling point, especially if you're using 1.7 rockers. The perfect length pushrod can come down to a difference of a couple of hundredths of an inch - 0.0xx. Saying definitively that you DO NOT need different sized pushrods is a bit misleading. I do understand what you mean though.fiveo'cobra said:What i'm sayin is with the Crane 2031 you do not need different size pushrods and you already have the 1.7 RR's. With the others you......don't. That's all.
but I have not seen anyone in a SN car try one yet on the boards.
I wont say bad things about other cams, but this one works for me!ProKiller said:i hear good things about the steeda #19 cam.
HoofnIt said:Myself and MattZ28 both have the Crower cam. Matt's car dynoed over 300 rwhp prior to installation of his KB blower.
MysteryStanger! said:BTW...what is all this stuff in people's sigs about "BARS"?
