Which Pullies?
rudeone707
1,829
Fairfield, Ca
Im going to do my balancer this weekend so i figured i might as well swap some pullies since one will be off already and ill have to remove the fan and maybe the radiator for the extra clearance. So which pullies should i go with? I was looking at either FRPP, ASP, or March. Who has the best quality? And where should i get them from? I was looking at thunder racing and they had descriptions that said 26% crank and 30% water pump, what does that mean?
I've had my 3 peice ASP set from Thunderracing for about a year and a half and haven't had any problems at all because of them. People are more than likely just going to tell you what they have. The car seemed to rev up a fair bit faster after I had the pullies installed. And for $100 you can go wrong. Im pretty sure those percentages are how much they slow that accessory down.
ASP Aluminum, powdercoated black. :nice: The only problems I've ever had was today when the 605 was closed and I had to take the street to get to school. Traffic was horrible. Took me 30 minutes to get just 3 miles. Car was running hot and volts were down a little. The 100+ temps didnt help cool the car down either. :nonono: Other than that though, I have had no problems. I do have the occasional drop in voltage when sitting at a long red light at night, but that is fixed the moment I start moving again. No matter what you go with, I will still be a good bang for your buck.
www.racenet.net has them for just under $100 check them out. :nice:
www.racenet.net has them for just under $100 check them out. :nice: asp.
I have the Mac billet steel pullies on the crank and water pump. I put the stock alternator pulley back on cause I did not like the alternator shutting off at idle in traffic. Definately a noticable power gain at the 1/4 mile.
