Which Trans. do I have?
RADA
36
Tucson, AZ
Hi guys,
I have one of those grey-area 2001 GTs. It seems to have some of the older 99-early 01 parts, and some of the later-01 thru 04 parts also.
My build date is 11/00
Want to order a Tri-Ax, been trying to figure out what trans. is in my car. Is there a letter or number code in the VIN that will tell me which one I have? :shrug:
Thanks,
RADA
If your door code has a K under transmission it's a T3650. Otherwise it's a T45.
http://www.pro50.com/ said:
FORD made TRANSMISSION changes half way thru the 2001
PRODUCTION year ON THE MUSTANG. Transmission APPLICATION
AND CONFIRMTION is NECESSARY. !!
THIS IS DONE by reading the DOOR code
on the drivers DOOR.(inside)
Here is a typical door code .
>BRK INTTR R AXLE TR SPR 2ZE2G
> 4 XW 9 LE K PP11 T05
>RC: 9F F0226
> R0181
THE designation for transmission STYLE and TYPE are located under the TR location.
__
IF your car has a K under the TR location as SHOWN above then your car
HAS THE 3650 transmission and REQUIRES the 3650 tremec SHIFTER.
