while I have the valve covers off, what can I do to make sure everything is good in there? get a wrench on everything and make sure that it is torqued to proper specifications? make sure there is no excessive wear on any parts? what should i do?
also what is that vaccuum tube that connect on the underside of the upper intake manifold, the bottom back corner of the upper intake manifold, and to the very back of the lower intake manifold. It has a valve on the end that gos to the lower intake manifold and it had a little bit of oil in the hose. What is this?
Should the inside of my upper and lower intake manifold be nasty, burnt and black?
Thanks
Thanks
