White exhaust smoke, help!!!
gt92seal
12
so... yet another day of trouble shooting iam about to give up. I have white exhaust smoke but no oil contamination,WTF, and torqued the new cobra lower and upper manifold correctly so shouldnt be any coolant getting in intake but...? lines are correct but im at a loss of words and just about hope only mode of transportation so i need this bad... and on top of the smoke there is no throttle when i hit the throttle RPMs go down and will kill it if i keep holding it. I truly dont know and am desperate. I am about to buy a ricer just to be able to go...:Total-CP:
did you put some silicon around the coolant passage between the lower intake and the heads ... and yea if your gettin water in the intake it will put out your spark and youll die when you give it throttle. could also be a blow in headgasket between the cyc. and water jacket
