I would love to hear ideas that may help, I have a 83 GT its got a stock roller bottom end, out of a 88. The problem is i cannot pull any better than a 1.89 60 foot, the car has a set of ported e7s with stock valves,a e 303 cam,a steath dual plane intake and a electric fan, stock shorty headers, with a factory h pipe the cats have been gutted, a 750 vac secondary carb. 5 speed with 3.73s, nothing i have done has helped, i changed to a 600 and a 650 carb still 1.89 or 1.90 60 ft,the only change was i went from 8.32 @ 85.3 to a 8.35 @ 83.9. I have changed every jet, sqiurter, combination possible, more timing, less timing, 3500 rpms, even a valve floating 6300 rpms i haved tried to launch at, no luck. carb spacers, i cant even make enough power to break the 7.5 rear, the car is lazy out of the hole but runs like a bat out of hell from the 330 to the end of the eight mile. even tried 4degrees advanced on the came nothing there any one have any ideas please help.
The 60' could be a little better , but what kind of 60' do you think you should be putting down with those number's? 1.80's aint all that bad for an 8.30's car.
