Why am I getting 11.5 MPG on the interstate?
The Green GT
No 13 year olds are safe around me.
1,269
Louisiana
I know I just put gears in, but even the 15 I was getting before that is horrible. I cant see why I get 11 MPG on the INTERSTATE. I am usually going around 75, but I hit 80 every once in a while. Ill go faster when Im passing someone. But since I noticed my horrible fuel economy, I dont really bother anymore.
New O2 sensors, cleaned MAF a few weeks ago, tuned up less than two years ago. Could use a tuneup I guess.
So what should I look into? Maybe the timing has something to do with it? I wouldnt think it would make my MPG THAT bad though.
Do you have any codes? I use my car to commute on occasion, and in all stop and go traffic, I'm pulling down 16-18mpg city. I haven't even checked my highway mileage, but I'm sure it'd be better.
air filter is usually the #1 cause of bad mileage...also make sure you have your tire pressure correct.
Is there any chance you are leaking fuel anywhere? do you smell gas at all (more than normal?)
Ill check the filter later. And I check the tires regularly. I set them right not long ago. And I have an O/R H-pipe. I always smell gas lol. But its always burnt. I never smell raw gas.
Last time I check ed codes I got nothing. And I was getting the bad MPG then too. But Ill do it again.
You said you just done some gears :D
Maybe your speedo is hosed and throwing off your miles driven :shrug:
Grady
My odometer doesnt even work. I checked the distance in my sisters car. Ive been riding to school with her in an effort to save $$. lol
And do gears throw off the odometer even if you have the right speedo gear?
With the correct speedo gear your odometer should be correct.
Not sure if you have tried any injector cleaner, I have had good luck with the lucas, I ran that in my wife's trailblazer before our trip to florida and loaded down with a/c on and the 5.3L we got 25 miles to the gallon which was a couple mpg better than normal. Also when was the last oil change? That could affect mpg
its hard to calcuate how your gas milage is without an odometer
but anyways
back when i was making like 8$ an hour and could barely afford gas I would drive 60mph on the interstate and pull over 20mpg
I drop an easy 5mpg by driving at 70mph
but anyways
I agree :D
To be the most accurate you gotta:
Fill up on level ground and get all in the tank you can
Write down the mileage at fill up
Drive until the tank is close to empty
Fill up exactly as before
Divide the miles driven by the gallons used
Very simple ... yet ... Very effective
Guessing about mileage or gallons used is just that ... Guessing
Grady
i get about 16ish in mine driving about 60/40 highway/backroads on stock 3.08s... driving pretty conservatively. u guys that are running over 20mpg on a consistent basis must all have 2.73s and spend 90% of your time on the interstate, i hardly ever break 200 miles on a full tank.
