Why am I getting 11.5 MPG on the interstate?
i get about 16ish in mine driving about 60/40 highway/backroads on stock 3.08s... driving pretty conservatively. u guys that are running over 20mpg on a consistent basis must all have 2.73s and spend 90% of your time on the interstate, i hardly ever break 200 miles on a full tank.
373 gears here. i get between 260-280 before fill up and usually fit about 13 gallons in there. thats with 50/50 city/highway. if i did only highway driving im sure i could see over 300 on a tank.
My odometer doesnt even work. I checked the distance in my sisters car. Ive been riding to school with her in an effort to save $$. lol
And do gears throw off the odometer even if you have the right speedo gear?
You can't get the correct speedo gear for 3.73's in a 94-95 with the stock t-5. With the 3.55 gear(white) you'll still be off by about 10%.
Driving at 65-70mph I got 18mpg when I took a road trip last summer. :) I usually get 8-12 around town tho :(
With the correct speedo gear your odometer should be correct.
Not sure if you have tried any injector cleaner, I have had good luck with the lucas, I ran that in my wife's trailblazer before our trip to florida and loaded down with a/c on and the 5.3L we got 25 miles to the gallon which was a couple mpg better than normal. Also when was the last oil change? That could affect mpg
Not necessarily true. I went from stock 2.73's to 3.73's in the rear and, even with the most correct speedo gear, my speedometer is definitely off. I do second the idea of trying some injector cleaner though. I especially advise using SeaFoam twice, once through the gas tank and once through a vacuum line. I had good results with it and it couldn't hurt.
After 3.55s you need to:
1 - Just deal with your stuff being silghtly high with a speedo gear change
2 - Change out the transmission gear and speedo gear to make a different ratio
3 - Use an electronic device such as a Speedcal
There is no single gear to drop in and correct for rear screw changes after you get past 3.55s.
Adam
I would check all the spark plugs and make sure every cylinder is firing clean. A cylinder balance test may lead you to a problem too.
Scott
Jack pot my #8 cylinder was not squirting properly, I pulled the plug and half was black and the other half was normal. The injector was squirting directly at the injector yet is was firing well enough not to miss and or hesitate. Pull the plugs and they will tell you whats happening. I ended buying a whole set of used injectors so if you need 1 or a few I have some.
If his speedo was off.... mine shows I'm going faster than I am... wouldn't that make your mileage appear BETTER as you are racking up MORE miles on a tank of gas? You could actually be getting 6mpg. LOL Or do I have that backwards? :shrug:
I would look for a leak. How's the rubber gasket on your tank? Show any signs of a liquid trail?
