  • 1994 - 1995 Specific Tech
Why do PRO-M meters have so many problems???
  • Thread starter Thread starter 95.0Stang
  • Start date Start date Mar 19, 2004
First Prev 2 of 2
HoofnIt
1,175
North Carolina
Mar 20, 2004
#21
  • Mar 20, 2004
  • #21
I've heard the only difference between the Fox bodied and 94/95 meters was the flanged housing for our cars. The electronics are identicle. Is there any truth to this?
Rootus
Officially Addicted
Feb 8, 2003
6,659
Portland, Oregon
Mar 20, 2004
#22
  • Mar 20, 2004
  • #22
Yes, that's true. And the electronics are similar enough with newer ones that you can easily make one from a newer Mustang work fine. A 90mm Lightning MAF is a relatively popular upgrade because it's a fairly inexpensive way to get a big MAF.
Stangfreak95
add a 4
3,571
In your sister. If none, your mom
Mar 20, 2004
#23
  • Mar 20, 2004
  • #23
Could you get any meter like a 80-90mm from a Lightning or a 80mm for a 99GT lets say, take the electronics out, send it to Pro M for a calibration for a 95GT for 24 pds injectors ? Would that work ? I'm so confused with that mass air meter stuff.
swingline
1,252
TCB - Taking Care of Business
Mar 20, 2004
#24
  • Mar 20, 2004
  • #24
Where did you guys buy your Pro-M meters?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Mar 20, 2004
#25
  • Mar 20, 2004
  • #25
I got mine direct from Pro-M when they were running their colored mafs on a close out sale.
Don't know but they might still have some left.
Later
Grady
Imyourzero
Learned that lesson as a horny teenager with lots
2,298
Hoonose, U.S.A. Posts: 39,051
Mar 20, 2004
#26
  • Mar 20, 2004
  • #26
Later
Grady
Wasn't the sale on the colored meters like 6 months ago? I doubt they have any left.
I've never heard of any consistent problems with Pro-M meters except the aforementioned 75mm Bullitt when used with 24# injectors. The 77mm and 80mm meters seem to work great! With C&L however, it seems like you're taking a gamble. For every person that says their C&L works great, it seems like there are 1-2 people that have had problems out of a C&L.
9
95.0Stang
538
Kansas
Mar 20, 2004
#27
  • Mar 20, 2004
  • #27
Would I be better off to just go with a 77mm Pro-M even on a stock motor if I plan to do H/C/I and eventually a SC?
HoofnIt
1,175
North Carolina
Mar 20, 2004
#28
  • Mar 20, 2004
  • #28
Without at least an intake OR full exhaust I don't think you'll see a noticable gain. I would rather spend that money on opening up the exhaust or putting in some different gears. If you do the meter now, you will have to spend at least 100 bucks to get it recalibrated for the bigger injectors you're going to need for the s/c.
J
jgstang1
texas
Mar 22, 2004
#29
  • Mar 22, 2004
  • #29
I bought a 75 pro m and it was giving me check engine light immediately. i plugged it in to a snap on scanner and got the live voltage while the car was running and found out that it was too little, that is what the code was for, low mass air voltage, so i called prom and they told me to run grounds all over because the batt was in the trunk, that did nothing, i sent it back and got another and it worked fine,. snap on scanner is really good for that because you can tune the voltage by rotating the housing while the car is running.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Mar 22, 2004
#30
  • Mar 22, 2004
  • #30
i went for the Pro-M 80mm in red....and will never switch my meter...EVER....i feel that the Pro-M 77's and 80's are the keeper meters....go with them and you will be satisfied...and are more than big enough to carry you further than most will ever go with mods.....and the 80 is cheaper cuz its plastic....
.....i also got mine direct from Pro-M when they were having the sale on colored 80's
Anthony
GTJake
3,049
Ann Arbor, MI
Mar 22, 2004
#31
  • Mar 22, 2004
  • #31
Anthony, did you feel any difference when you put yours on? I'm going to wait until after I'm done with the head/cam swap before I change mine out.
Jake
FastFord
380
Washington
Mar 22, 2004
#32
  • Mar 22, 2004
  • #32
This thread is interesting. I have had PRO-M since 1999, two 75mm bullit meters, one calibrated for 19lb injectors and the other calibrated for 30lb. I have had no problems in the least. I have also had a superchip for the entire time, perhaps it has saved me... or I have been lucky.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Mar 22, 2004
#33
  • Mar 22, 2004
  • #33
Jake,
I did notice a little bit with the 80mm....the mods i had at the time were 65mm TB, O/R X, and catback....i did the CAI the same time....i would check out Pro-M's site and see if they are still running the special on the colored 80mm's....cuz if they are id jump on it since it was real cheap......i dont wanna go quoting prices cuz im not sure if they are still that cheap...
Anthony
Killercanary
The car that set the bar.
Altoona, PA
Mar 22, 2004
#34
  • Mar 22, 2004
  • #34
http://performancepartsmall.com/detail.asp?id=122
There's the price from Pro-M's site.
VIPERn94Five-0
3,352
Poughkeepsie, NY
Mar 22, 2004
#35
  • Mar 22, 2004
  • #35
http://performancepartsmall.com/detail.asp?id=443
there is the Red or Blue one....dont bother getting the mounting hardware...you wont have any need for it....
Anthony
First Prev 2 of 2
Pro-M 75MM Bullet Flow Sheet - Is this calibrated for 36 # injectors?
  • dan50
  • Jan 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 11, 2026
dan50
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2025
from6to8
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
