I've dropped a 306 into my 94. HCI is all edelbrock performer stuff. Is anybody else running this set up? I picked up 24lb injectors and a 70mm throttle body. On the first start, we had to keep the throttle wide open to get it to run and it barely hit 2k rpms. Finally started letting off and it'll rev higher now, but it still won't idle on its own. This is the first time I've done this, and I know it's vague... but what are my next steps? FWIW, I'm using the edl-3722 cam, I believe it has the same specs as an E-cam and in past research I've heard the 94-95's have a problem with the E-cam. Could this have anything to do with it?
Have you verified the recommended spark plugs........just asking.......
