Wideband Now connected Now what?
m0l0
178
Hi there all :SNSign: Members.
Well ive been a little offline in the tuning board. but i am now back with some Q´s.
I have succesfully connected the LC-1 Via EVP port to the EEC and tweecer is working fine , i just need some adjustmens on the table because the LC Soft is showing top 10.5 AFR on WOT and the calcon is reading 9.5 but on the CL on 14.6-14.7 is working fine. I will work on this latter.
However i am shoing a really rich AFR on WOT going from 12:1 to 10:5 on the end where should i start to lean a little on the WOT_Fuel_Multiplier VS RPM. or work on the MAF Transfer ( I know the MAF table is 10% enrichened by me i will log latter with a 5-7% lean ) but the question is what is the better way to correct wot afr via the function on the eec or tweak the maf transfer?
I also have to disable the Fuel Enrichment for High Speed and test. but the main question what is the best way to adjust the AFR on the EEC. show me your points of view on this matter.
I can post the Log file from the Tweecer and the LC-1 Log if you want to.
Thanks in advance :nice:
IIRC ... I got detailed info on past posts here
and
I got detailed info on my site
however
I'll give you the info with just the main points
but
first of all ........
It seems to me you wanna get setup so you got wysiwyg.
or
What You See Is What You Get :nice:
The very reason you got a wb is to have a known reference point ;)
Do what you gotta do ... to know :D
the value you see in your data log is 100% Accurate or True :Word:
Now ... about that ... WOT_Fuel_Multiplier VS RPM :shrug:
That sounds like Fox Speak to me :eek:
but ... I don't know :scratch:
I ain't saying it can't be used :nono:
I mean ... I looked ... and its in the CBAZA file and all
but
It don't appear that is is in place and doing anything
I just ain't seen anybody use it with our cars :shrug:
If you have not dialed in your inj's, (slopes, offsets, etc) inj timing,
and the other various stuff you usually do for a stable CL tune,
you don't wanna setup your final WOT ratio as it will become moot
or voided later on when you go back and dial in that other stuff.
Just double work for you ... don't ya see ;)
anyway here are just the basics steps :D
After you get a stable CL tune ... you should know ... by then ...
where the point in your maf curve is that divides CL and OL.
You work with that top portion ... for your WOT af ratio :D
You set the greatest load row of the fuel table fat ... like 12 to 1
You kill the high speed enrichment function
You dial back the total spark advance very conservative
like ... maybe 22 or so ... again ... the greatest load row
Make a baseline pass in third gear at WOT from say 1500 to
say 4500 rpm ... Redline is not advised at this time :nono:
Look at your spark in that baseline dlog to ensure in fact
it was as you commanded in the spark table
and
In that same baseline dlog ... look at your wb data column to see
if you were fat or lean using the lambse values you commnaded in
the fuel table as a reference.
Adjust the maf cells kg values accordingly.
After the 1500 to 4500 part matches .......... you most likely will have
to find a more suitable place for redline passes as the speed will get
a good bit higher at that point. We wanna be safe ... Don't We :nice:
After the entire upper portion of the curve has been optimized
then
you don't need to deal with the wb for WOT ratio choice
cause
Your fuel table now has been ...... WYSIWYG'ed :banana:
There you have it :D ......... Make Sense :shrug:
If not ... look at the info I talked about above
and
if still ... something seems not to make sense
Do Not ... Do Not ... Go any farther :nono:
This is the part where you can hose up ... big time :eek: :shock:
Ask and be sure on this part :nice:
Someone will clear up what I messed up with my splaining :rlaugh:
Grady
Thanks Grady I dont know why but i was sure u will be the first responder to this :nice:
Well i am sorry but i didnt looked on your site before posting i didnt remember the WOT tunning seccion, but now i have another question according to your experience how acurate is the EEC commanded AFR to the final AFR , of course dialing the MAF transfer to the most acurate?
Another thing reading the datalogs i have concluded that the 1:1 AFR diference it will be corrected on the INNOVATE.DBF Volts VS AFR i have used the original calcon settings and just configured the LC1 to output a linear 1v - 10AFR, 2V-20 AFR how ever i think the EVP port is not too acurate within the 1-2 volts range i need to make a 10 - 20 afr using the full 5V range the evp input provides but i need to make the table to the calcon. and the other 1:1 afr diference is about a 10% rich i have made in the MAF transfer previously , that makes a 2% diference within the commanded EEC afr and the real AFR , i will make some changes today and try. I would really like to see a 12.5 commanded AFR and a real 12.5 AFR , that would make the tunning sooo easy on a future.
I'm guessing you are talking about the WOT fuel ratio :shrug:
So ... whether the commanded value is close or way off ..............
It just don't make no never mind.
I've seen some be close and some be far off :shrug:
There is usually more than one way to do these pcm
value changes that will get you to your desired goal :D
I've worked with some who did not know the Cobra made things
fat after 90 mph ... but ... they got that last part of their curve dialed in
never the less ... so ... see what I mean here.
We put all these parts on our cars.
Some combos end up needing more attention in some areas
of the tune and with others ... they need less.
All that matters is you understand what needs to be done
and
How you go about doing it with the pcm values
The data you gather tells you what is wrong and what to do ;)
Yes ... I've seen some say they needed to play around with things
to make the readings in CalCon read accurately with that wb
but
I just can't help you there as I have not done any of that kinda thing
but
So many have been where you are now with that wb
and
That means they have paved the way for you :banana:
All you gotta do is dig up their info on the various boards and you are
on your way :)
I would start fatter just to be safe ;)
btw ... When working with spark or fuel and doing it WOT
Just remember this little mantra .........
Big Fuel ... Little Spark ... Good :nice: Little Fuel ... Big Spark ... Bad :notnice:
Kinda Korny :rlaugh: but it gets the point across I guess :D
Hope I understood your concerns correctly and helped in some way
and
Seriously ... If you are not solid with this particular part of WOT tuning
Several peeps here have done this and can help you
Grady
