tomustang said:that aint no wide rear![]()
..........for that case I dont think you want a WIDE REAR if you know what I mean.
cvgtpony03 said:She doesn't have much junk in the trunk or in the attic. .
The 03-04 cobras run 275's all around, but those are on the 17x9's with a 26mm offset. I've also seen plenty of people running 275's on the stock 17x8 rims (which I discourage).Stangdriver1119 said:How wide can we go up front on our stangs without any rubbing issues or with it being to wide that it sticks out past the fenderwall? I want to go 275's all around so I don't lose my rotating ability on my tires, but I'm not sure if 275 is too wide. This will be on 17 inch wheels by the way
Stangdriver1119 said:wow those match up with the fenders like perfectly on your car....nice man
Killa Klown said:Wheel Style: Bullitt Wheel Size: 17x9"
Wheel Backspacing: 5.95" Wheel Offset: +24mm
Wheel Weight: 23 lbs. Bolt Pattern: 5 x 4.5 inch
Wheel Style: Bullitt Wheel Size: 17x10.5"
Wheel Backspacing: 6.84" Wheel Offset: +27mm
Wheel Weight: 25 lbs. Bolt Pattern: 5 x 4.5 inch
Ok heres the specs. on the front and back
I have no rubbing issues what so ever
