Widest tires on lowest 'stang
carlmb
11
boston
I am looking for pictures of the lowest Mustangs with the widest tires. I am planning my latest project. Looking for an early coupe. Planning on Heidts narrowed font end, narrowed rear end with mini tubs and springs moved inboard, weber downdrafts on a stroker. Help me out with some pictures and ideas. Thanks, Carl.
narrowed font end
HUH? :shrug:
narrowed rear end
Ok, but this doesn't change the amount of rubber that fits the car, it changes the backspacing needed on the wheel that holds the rubber
Uh, ok...so which is it? Mini tubbing it or moving the suspension around like you would for just plain old regular tubs?
What does this have to do with fitting tires?
:D
http://www.dodgestang.com/motor06-2.jpg (same as sig)
Lower on 620 drop springs front and mid-eyes in the rear
245 40 17 front
255 40 17 rear
396 RWHP / 355 ft lbs (oh wait...that wasn't tires)
17x7's and 17 x 11's with 5" of backspacing with a shorter rear end.
brin0357 said:
I dont have pics but one of the stangs we built had 20 x 10's all around.
Pics and a description of mods performed are completely and utterly necessary for me to believe you had 20 x 10's in the front on any Mustang prior to the Fox body cars. If it was a Fox body or later, cool, but not really applicable here.
In reply to Dodgestang. Heidts makes a 2" narrower front end kit to allow for more tire without having to use a wheel with more positive offset. I have built pro-street cars. Not what I am looking for here. By moving the suspension inboard and widening the stock wheel houses I can maintain the rear seat and don't need a fuel cell. Also by narrowing the rear axle I can use a deeper dish wheel with less positive offset. A better look in my mind. Just looking for pictures and specs.
