Wierd Smell
Lovejoy
Jerking And Popping
Jan 3, 2016
94
Illinois
hey guys question here. threw on 70 mm tb couple weeks ago. seemed to be burning antifreeze right after install a lot of white smoke. not nearly as much now weeks later but does smell very odd and smokes a little. wondering if i could have some tiny leak of coolant or maybe running rich or lean. any comments would help. car runs cool and good so kinda confused. thanks
I had the same thing. I got a 70mm Acuufab TB and the gasket didnt work at all, and the coolant that goes through the EGR seeped into the intake pipe and down the manifold. I just bypassed the EGR line, but I live the Houston so I don't have to worry about my TB icing over. If you live in a colder area I wouldn't recommend doing that.
It might just be easier to get some rtv and put a generous amount around the edge of the TB and EGR. When you unplug those 2 hoses, coolant is gonna come out. Then again if you take off the EGR it will too. If you can, maybe, squeeze the 2 hoses with something that doesn't have teeth.
Most leaks are due to failure to clean the old gasket residue off before installing a new gasket. Good Enough" means that you have all bare shiny metal and no dirt or debris stuck on the gasket mating surfaces. Painstakingly scraping the metal mating surfaces with a razor blade scraper is often difficult to do and inconvenient, However, it is a very important part of the assembly process.
While this sounds overly simple, it is all to easy to do a minimal clean up and slap it together. Clean shiny metal, a thin coat of RTV on the metal surfaces, and a fresh gasket will guarantee a leak free seal every time.
Reactions: stykthyn
