Will a 70mm Throttle Body Bolt up to a stock EGR Spacer?
Kdubslugga
1,515
Akron, OH
Heres the deal i scored a good deal on a Polished Mac 70mm Throttle Body, and im bolting on a Cobra Intake in like a month or or 2, i dont wanna buy a 50 dollar or so EGR Spacer, when the Cobra Intake will have a built in spacer, so my question is for right now can i bolt the new 70 mm Throttle Body to the stock EGR Spacer without any problems???
Starscream88 said:
No it will not fit on a stock EGR,
Only the stock TB will,
You will have to wait or get a EGR spacer
not even a 65mm will fit. Only stock.
I believe it will fit. Only the bore sizes are different. When you order various sizes from aftermarket, none of them ask what manifold it's going on. The bolt pattern is the same size. Please correct me if I'm wrong.
i bored my stock opening to 70mm using a 2.0" tube sanding bit, just lay your knew 70mm gasket on the throat of your egr, then your intake face and scribe it with a sharp punch or screwdriver. pack lots of rags into your intake throat and duct tape the lower openings, start removing aluminum slowly moving the drill around the opening in complete circles, keep going until that scribe mark dissapears and your done. i ported some of the corners a little to get a little more circle to the opening of the intake. i also bought my 70mm spacer so i only had to do the intake but i could have done the spacer the same way good luck my 70 works great its a mac also.
You're right. It will fit but wouldn't do much good since the egr spacer would be choking it off.
