Will I benefit?
zeevann
55
This winter in my build (basic boltons with PI cams and intake) I want to upgrade fuel injectors and fuel pump. Ive heard that it may help, or it might just do nothing at all. I was wondering what :SNSign: thinks i should do. What size injectors? Also if I uprgrade injectors do I have to change the MAF?
Thanks for the help once again:nice:
I wouldnt mess with the injectors unless your gonna be going FI soon. Save the cake and spend it on something else. The pump you could do if you want but you wouldn't need to. How many miles are on the car? BTW this is probably gonna be moved to tech
OOPS I thought this was tech sorry..... my bad:(
another reason why i thought of doing this is because i believe my fuel pump is on its way out. When i start the car cold it dies right out. I changed the fuel filter, fuel pressure regulator, gas is good, so i can't see it being anything else.
