Window drip rail came off!!!
  • Thread starter Thread starter Mstng67289
  • Start date Start date Jun 14, 2004
M
Mstng67289
68
Atlanta, GA
Jun 14, 2004
  • Jun 14, 2004
How in God's name is this supposed to go back on??? I've tried clamping itself back on using the molded sides of the trim but no luck; it isn't a solid fit. It hasn't totally come of, but the back 1/4 length of the driprail has come off of the railing on the passenger side of the car. Any suggestions would be greatly appreciated.
G
geegee
2,015
near Oklahoma City, OK
Jun 14, 2004
  • Jun 14, 2004
Here's how I did mine. Need two people. Second person simply holds the molding in position while you snap it on. Just snaps on, you know? I took a 8" long 2x4 and covered it in several layers of soft cloth. I wrapped it tightly on the 2x4 and then stapled the cloth. Use the unstapled side only to install the molding. Starting at the rear of the drip rail place it in position after lining it up so you know where the ends will be when its installed. Use the wood block as a hammer to drive the molding on. Note that it installs over the top of the drip rail and snaps on at the bottom. Once the rear part is installed, 12" or so, then have the second guy hold it on with his hands. Steady pressure is all that is required. Work forward with the 2x4 hammer until you have the molding completely on. Once its completely on, it will remain on. Note that if any of it is loose, the entire length will pop off immediately.
Problem areas:
If the drip rail is freshly painted, you may have to sand off the paint and reprime the metal. Its important the drip rail be clean and the painted surface thin and uniform (no thick paint). The drip rail does not need any paint except primer where its not exposed. You'll be surprized how easy it goes on when the drip rail is clean on the areas where the molding covers it.
M
Mstng67289
68
Atlanta, GA
Jun 14, 2004
  • Jun 14, 2004
yeah this drip rail has so much paint on it it actually looks more like it was done with bondo!!!
I'll get a pic soon and show you what i mean
1989 Passenger side electric window issue
  • Sanchez_005150
  • Jul 17, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 4, 2025
WillWho?
W
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
R
1994 GT 5.0L crank no start
  • Red1994MustangGT
  • Apr 15, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Aug 19, 2025
Kurt_MO
K
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
