wiring diagram needed, 1981 6 cyl. Mustang
mikeAZ
27
Arizona
At sometime, the under hood/ ignition switch wiring wiring was cut. A color diagram would work best... Is my only recourse EBAY?...and then who's reproduction is most accurate?..Mike
What part of the harness was cut?
I don’t have 1981 in my pile of EVTMs, but the linked manual is what i would buy. There’s a couple 1981 mustang EVTM for around $20 shipped on eBay.
I only have 86-93 otherwise I’d post screen grabs of what you need. One day I’ll collect em all.
Reactions: General karthief
Looks like most of the underhood wiring is cut at the firewall...."Some" of the wiring was spliced and run outside the inner left front fender so as to be not visible with the hood up, in an attempt to hide the wiring??? There was an attempt to eliminate the ignition switch and install a push button in it's place..... Most of the vacuum lines are disconnected for some reason.... I'd guess a V8 was planned?.... The car is otherwise in remarkably good condition, otherwise
Mike,
This is what you need. I used one for my '93 5.0 swap into a '54 Ford and thanks to this wiring diagram I was able to retain the factory fuel injection. Everytime I do a swap, I get one of these. These are what the factory techs used in the dealerships before everything went digital. It covers every circuit in your car!
1981 Mustang factory wiring diagram
I ordered it...Thanks, I'm sure some of the diagrams are just so, so. Next are the vacuum hoses...
Reactions: manicmechanic007
mikeAZ,
The above posts are all correct
I like books and have many
The library has the exact manuals you need in digital printable format
All Data for free
5 libraries within a 20 mile radius
City life sucks
If you live in the sticks the library probably offers it free from their website after you punch in your card info
