wont start
  • Thread starter Thread starter 5.0Torx
  • Start date Start date Mar 28, 2009
5.0Torx
252
Mar 28, 2009
  • Mar 28, 2009
hey all
After a long week working on swapping GT40Ps and an explorer intake on my car, i tried starting it up tonight.
The build is: GT40Ps, cobra 1.7 RRs, trick flow springs, trick flow timing chain set at OEM cam timing, explorer intake, 70mm TB and a C&L 73mm MAM. Stock bottom. Swap done with engine in car.
It has fuel. Ive gone down the cranks but no start checklist from jrichker and have a few ideas, but im still at a loss.
Its throwing codes 21, 23, and 24.
Please help!
5.0Torx
252
Mar 29, 2009
  • Mar 29, 2009
heres more info.
i think its exploding gas in the exhaust. i had the midpipe slightly off the header collector at first and was very alarmed to see flames shooting out of the gap. i realigned the exhaust but it still wont start.
i thought i might have had the dizzy 180 out so i flipped that around and it still sounds like its exploding gas in the exhaust.
HISSIN50
34
129
Mar 29, 2009
  • Mar 29, 2009
Where on the list are you not able to pass?
5.0Torx
252
Mar 29, 2009
  • Mar 29, 2009
i havent checked that i have spark but im assuming i do because im exploding gas in the exhaust. Im also assuming i have fuel because my garage stinks of it while trying to start it up.
so...
6.) Spark & fuel pressure OK.
A.) Failed IAB or improperly set base idle (no airflow to start engine). Press the throttle ¼ way down and try to start the car. See the "Surging Idle Checklist for help with all your idle/stall problems.
C.) Engine ignition or cam timing off: only likely if the engine has been worked on recently).
HO & 351W 1-3-7-2-6-5-4-8
Non HO 1-5-4-2-6-3-7-8
E.) No start when hot - Press the throttle to the floor & try starting it if you get this far. If it starts, replace the ECT.
A Compression check sounds interesting but i havent figured out how to get all of the plugs out since im not running P specific headers.
I was super careful with my cam timing. Im pretty sure its OEM or damn close.
I think its ignition timing but im confused because flipping it 180 made no difference. I would think that one way would start right up and another way wouldnt start at all. Both ways seem to be exploding gas in the exhaust.
HISSIN50
34
129
Mar 29, 2009
  • Mar 29, 2009
Assumptions allow simple things to get overlooked and chew up lots of extra time.
That said, are you sure the dizzy was stabbed on the compression stroke and that it's in time?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 30, 2009
  • Mar 30, 2009
Make sure you have spark and injector pulse. Use a Noid light to check for presence of the injector pulse. The presence of spark and 12 volts on the red injector wire with no injector pulse suggests TPS problems if the TPS is connected.
The code 23 (TPS too high) can shut down the injectors. Disconnect the TPS sensor and try to start the engine.
  • dan50
  • Jul 18, 2026
dan50
Hello Everyone !
  • 5150K
  • Jul 3, 2026
  • The Welcome Wagon
The Welcome Wagon Jul 3, 2026
5150K
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Engine Help hard/no start runs rough.
  • Mr.Kelley
  • Dec 24, 2023
  • 2 3
6K
Fox 5.0 Mustang Tech May 19, 2024
manicmechanic007
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
12K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
