Umm, wood + gasoline vapors= termitesFoxfan88 said:what if i were to coat the wooden spacer with some fiberglas resin or something. To where the wood would never be exposed to anything...
i mean we build houses with wood, and they stand for YEARS, if wood is so bad lets build all our houses with aluminum or cast iron.... i dont see how a wooden intake spacer would be too far off the spectrum, it will be exposed to alot, but so is a wooden house and it gets alot more abuse.
i would rather try it, bc obviosly it hasnt been tried enough and documented the results on it.
85_SS_302_Coupe said:Again...i'm gonna jump in here and remind everyone about wooden carb spacers. Have none of you really ever seen one? I've seen 7 second alcohol cars with F'in wood spacers....and i'm not even joking. Hello guys....how long were boats made of wood? It's not like gasoline just rots the $hit out of wood and that's that. Like i said you need a layered plywood similar to what skateboards are made from, and you can't half ass it. Again, i wouldn't run boost with one but i don't see any reason it wouldn't work. It may not last forever but it can be done.
You guys need to stop busting balls and be supportive even if you think it's stupid. You can give advice but some of you are being dicks. If the guy fails, he'll learn a lesson, which is more than some of you will ever get sitting there typing insults on a keyboard.![]()
25thmustang said:This isnt a joke???
Sonny Leonard said:"If a guy wanted this, we could make it with 10.0:1 compression to drive on the street. It would make 1,175 hp on pump gas."
Figures, Its a HEMI!Henceforward said:Far from it, check out this December 2005 CarCraft article, pg. 34...
762CI 1,620 HP
"The Wooden carb spacer helps to dissipate heat, making the bowls on the twin 1,350-cfm Bo Laws Dominators 25 degrees cooler than the surface of the intake runners."
795.0pacecar said:That looks like laminated plywood on a race engine. Thats a great comparison for the 1" spacer made of cheap wood that foxfan was thinkin about making.
Oh man, I want to see the follow up thread to this one!
