Here is some basic information on the different heads...
WRL-053030-1 - Windsor Jr., Iron, 180cc Head, 58cc, 1.94"/1.60" Valves, 1.250" Single Valve Springs (.560"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $940.
WRL-053030-2 - Windsor Jr., Iron, 180cc Head, 58cc, 1.94"/1.60" Valves, 1.437" Dual Valve Springs (.600"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $1,020.
WRL-053040-1 - Windsor Sr., Iron, 200cc Head, 64cc, 2.02"/1.60" Valves, 1.250" Single Valve Springs (.560"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $940.
WRL-053040-2 - Windsor Sr., Iron, 200cc Head, 64cc, 2.02"/1.60" Valves, 1.437" Dual Valve Springs (.600"), 7* locks, 3/8" rocker studs, no smog provisions, and not machined for o-rings, 1/2" bolt holes. $1,040.
More Windsor Sr. Head Information:
(-1) models get .560" springs that have 100# seat pressure.
(-2) models get 'racemaster' forged valves and .600" springs have 125# seat pressure.
(-3) models get 7/16" rocker studs, 'severe duty' forged valves, and 10* locks.
Intake Port Gasket – Fel-Pro 375-90361 or equivalent.
Exhaust Port Gasket – Fel-Pro 375-1415 or equivalent.
Head Gasket – Fel-Pro 375-9333PT or 375-1011-2 or equivalent. Caution: 375-1011-1 is not recommended.
Head Bolts and Studs – 7/16" with bushings or 1/2" Standard.
Spark Plugs – NGK 2817, 2405, 4323.
Maximum Angle Mill - .175"
Flat Mill - .007” per cc (approximate).
Maximum Flat Mill - .040" (intake seats).
Airflow Chart for World Product Windsor, Sr. Heads:
Inches - CFM - CFM
0.100 - 061- 052
0.200 - 125 - 099
0.300 - 163 - 122
0.400 - 198 - 138
0.500 - 220 - 151
2.02" in./1.60" Valves.
