V8? Naw, been there, done that.
V10? Viper's already got the cache on that.
So how about...
V12?
Crazy? Probably, but what the hell, why not have a little fun on these forums
But here are some rationales:
Heritage: Every Mustang once had a V12 -- the P-51 Mustang that is. If you want heritage, then let's go all the way back to the Mustang's namesake.
Availability: Ford has already engineered Duratec-based V12s as seen in various show cars and even in their Aston Martins, though that version is highly modified and hand built.
Cost: As per the above, the engineering has basically been done and could, for the vast majority of its parts, use off the shelf Duratec pieces, which would be good not only for initial affordability, but also stocking replacement parts for dealerships.
Power: Even just scaling up Duratec specific outputs, you would get a 400hp 5.0 (2 x 2.5 Contour SVT's 200hp) or a 480hp 6.0 (2 x Jag 3.0's 240hp). Either of these specific outputs could readily be increased to get well over 500 in the 6.0, naturally aspirated.
Sound: For anyone who has heard a V12 with a good exhaust system, I need say no more, an uncanny symphony of silken refinement and commanding raw power. A foreboding Grizzly growl at idle, a banshee wail in the midrange and a spine tingling shriek of the Valkeries at redline ... must be heard to believe.
http://www.jag-lovers.org/brochures/sound/v12e.wav (and this clip hardly captures the full richness and range of a V12 sound.)
Size/Weight: Not sure of this, but the Duratec based V12's are all AL and, if I can recall, reasonably compact and light, probably on par with the V10 Mod motor.
Other: The ethereal, turbine smoothness and Kansas plains power/torque curve are something to be experienced, the surreal smoothness gives a real iron fist in a velvet glove demeanor. And again, the distinction for a higher-end Cobra -- Vette's already got a V8, the Viper the V10, what's left for Ford to set apart the Cobra?
Admittedly, this is fairly pie-in-the-sky, but it would certainly give Ford and the Mustang a huge distinction in terms of being the first truly mass market V12, which would echo Ford's intent with the original flat head V8 being the first V8 for the masses -- how's that for some more heritage?
