wtf??????
  • Thread starter Thread starter 83stang
  • Start date Start date Mar 21, 2004
83stang
165
the shop
Mar 21, 2004
  • Mar 21, 2004
well i just got done installing a set of upr upper and lower fully adjustable control arms and now my car makes a whining noise and sounds like crap. I checked the angle of the rearend and lined everyhting up and it still sounds like crap anyone got any clue what the deal is? thanx
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Mar 21, 2004
  • Mar 21, 2004
Can you describe more -- are you talkign vibrations or exhaust noise or what? Where is it coming from?
83stang
165
the shop
Mar 21, 2004
  • Mar 21, 2004
well its kinda weird sounds like its coming from the rearend its like a whinning noise. Now i noticed it goes away though if im driving and i push in the clutch and coast down a hill i dont hear anythign but as soon as it goes back into gear it whines, and you hear like a rattling noise and just a weird noise that sounds like its coming from the rear end. Now i chekced my mufflers to make sure they wernt rubbing with the driveshaft and one of the mufflers i couls put my fingers between it and the driveshaft but the other one wasa little tighter but not touching. hope this helps.
5.0's 4 ever
The #1 Stunna
5,794
Orlando, FL
Mar 21, 2004
  • Mar 21, 2004
You checked the angle of the rearend correct, what degrees was it at after you finished your install?
83stang
165
the shop
Mar 21, 2004
  • Mar 21, 2004
as far as i know i checked it right its at 5 degrees
83stang
165
the shop
Mar 23, 2004
  • Mar 23, 2004
anyone else got an idea? whats the deal?
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Mar 23, 2004
  • Mar 23, 2004
That sounds like a lot of angle for solid or poly bushings (according to my reading) -- but I don't really see why it would make it whine. Whine sounds more like a gear related problem...or at least coming from the gears. It's possible you're hearing the rearend more than you did before -- that's my best guess.
I just finished my setup -- very similar to yours with the UPR uppers and lowers. Mine are all metal excetp for the axle end of the lower is poly -- so it's alot of solid. I can hear all the road noise in mine without the backseat in and no insulation or tar on the floor. I can also hear my rear screaming! I also just had my rear setup with 4.30's and very loose, so that could be why in my case -- but we're going to put a little more preload on my setup and put in my backseat and see how it sounds. It might just be not as loud as I think.
Just something else to think about...
83stang
165
the shop
Mar 24, 2004
  • Mar 24, 2004
ya i was thinking that just the other day i might just be actually hearing things that i didnt before because of the setup now. Thanx for the input
C
Suspension Rear suspension help
  • Clark302
  • Aug 17, 2025
Fox 5.0 Mustang Tech Aug 17, 2025
Clark302
C
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
