Yes Or No On Edelbrock Heads
Mike, I would stick to the 9333pt1 gaskets. The cosmetics are great and I swear by them on my motor but in a build like yours the head gasket can act as a fuse @madspeed. If something goes wrong, mechanically, tune up wise etc the worst you'll do is blow a head gasket. I have literally melted a hole out the side of a cylinder head running a cosmetic and having a mechanical failure. As for the rest of the parts, it seems to be pretty comprehensive. I would rather see head studs than bolts but that decision is yours. I'm not a Huge chrome valve cover fan myself..they always seem to leak but that's my .02¢
As for a timing chain, any good double roller will do. I personally always stuck with comp cams.
Polished stocker valve covers over new stamped chrome ones any day! I second the 9333 pt1 head gaskets. I just finished replacing my hg and all the resesrch i did said 9333vall the way
Wondering why they recommend the HG with the tin fire ring 8458 vs the steel one- 9333 pt1 on alum heads. Softer metal in the heads? They actually like the 1011's which I know leak and fail.
That I dunno, I talked to a few engine builders and noted Mustang tuners before buying my replacement gaskets. Pretty much all said the same thing, "get the 9333 pt1 unless your planning serious power, then let's talk more about your specific combo and plans".
Gheez, I thought you of all people would know they are COMETIC
:bang:
Reactions: 84Ttop
Hell I didn't know your account had posting privileges. I just always scroll through a thread and see you "liking" everything and then you disappear into the night. I feel like I've caught you in the wild right now
Lmao. I do like the "like" button lol. A lot of times it's for a post that already states my opinion and would be redundant to post. I have posted over 1000 times so I'm not just a Lookee Lou:shrug:
Mike I've used both the comp and frpp timing chains in the past also. I also 2nd not using chrome valve covers. I'd polish the stockers or maybe some polished fabricated covers. I also would run a custom cam but you can't go wrong with a tfs1 or equivalent. Sounds like a solid build to me.
Hate to say it, but I almost try and avoid anything FRPP these days. They outsourced most of their parts from China and the quality has gone down. I did install FRPP gears in the rear though.
Took me about 4 hours to polish up the set of VC on the car. They look great but damn you got to keep polishing them every month or so. The chrome ones I have are the real ford stockers that were chrome plated, not some repop cheapos. I've used them before with the felpro rubber and steel vc gaskets with success. I'll deal with it when the heads are off.
Fighting the urge to spend the $$ on a 1 piece input shaft and a Dirty Dog or Edge 2800 stall TC. Must step away from the computer.................................
Yeah I've heard that also. I've got their gear set/diff in the garage waiting to be installed also.
The cost of it has to be considered. If you spend $1100 for E-street heads, and then the first thing you have to do is spend $200 for valve springs, then spend 2 hours installing them, you didn't save any money.
Kurt
