tried the search option...and came out empty...I have a T-5 tranny that is a Tremec T-5 since it is a 92...I ran the number's on the tranny to verify that it was...anyways...the problem is that for some reason I cannot downshift to 2nd gear...and if the tranny FINALLY allows me to...its very hard...Now when I start out from 1st, and than go to 2nd and so on...it's perfect...no noise, goes in with ease...so I don't think that's the syncro...or is it? but if I'm in 3rd or 4th and am in the proper RPM to still downshift to 2nd I can't...WHY? Also same deal with 5 gear...for example when I go from 5th gear to neutral...and than when I try to put it back into 5th again it will not go in...SO I have to put it in forth but not release the clutch and than quickly go to 5th again...WHY? Is it that maybe my clutch cable is stretched out and is not disengaging from clutch...? Am I low on fluid? what should I look for? it's not the shifter...I alreay swaped that out...this is very puzzeling to me...
thanks guys...
thanks guys...
