Wheel/Tire - Need your info for FAQ
gp001
4,401
So. Cal.
OK Members, I am testing out the usefullness of doing FAQs for the S197 Tech Section. I am going to start with one for wheels/tires. If it proves sucessfull I will move on to other areas.
What I need from all of you with NON STOCK wheels is:
Wheels:
Brand
Model
Wheel Diameter
Offset
Did you need/use a spacer?
Tires:
Brand
Model
Size
Suspension Mods if any
A picture. Preferably small. Can also be a link if A) it is your car, and B) you have the right to link to that webspace.
The only information I want in replies to this thread is the info above. No "Where'd you buy those", "Those look great", etc. Use PMs or e-mail for that.
Wheels:
Brand - ROH
Model - Drift R Black
Wheel - Diameter Front 19x9, Rear 19x10
Offset - Front +35mm, Rear +45mm
Did you need/use a spacer? No
Tires:
Brand - BF Goodrich
Model - KDW 2
Size - Front 275/40-19, 295/35-19
Eiback Pro Kit
BMR Adjustable Panhard
BMR Adjustale LCAs
wheels/tires
Wheels:
Brand - Bullitts
Model - Deep dish
Wheel - Diameter Front 18x9, Rear 18x10.5
Offset - Dont know took off from my 02 gt (rear wheels sticks out a lil bit)
Tires:
Brand - Nitto
Model - 555
Size -265/30/18 rear 285/30/18
Suspension Mods
Eiback sportline springs
Bmr adj panhard
Wheels:
Brand - Axis
Model - Hiro
Wheel - Diameter Front 19x8.5, Rear 19x10.5
Offset - Dont know
Tires:
Brand - BFGoodrich
Model - g-Force KDW2
Size -245/35/19 rear 295/30/19
Suspension Mods
NONE (yet)
Wheels:ADR Spartan Racing Wheels (Chrome)
Brand - Spartan
Model - Deep Dish
Wheel - Diameter Front 19x8.5, Rear 18x9.5
Offset - ?? They are wide as hell though
Tires: KDW
Brand - BF GOodrich
Model -
Size -295/35/19 Rear and 255/40/19 Front
Suspension Mods
Steeda Front Strut Brace
Wheels:
Brand - Cragar
Model - SS 230
Wheel - 18 x 9
Offset - +36mm
Tires:
Brand - BF Goodrich
Size - 255/45ZR18
Suspension Mods
Eibach Prokit
Steeda Billet LCA
Wheels:
Brand - Ford
Model - Grey painted Bullit (GT Take-offs)
Wheel - Diameter Front 17x8, Rear 17x8
Offset - Front stock, Rear stock
Tires:
Brand - Pirelli - Front
Model - GT Take-offs
Brand - BF Goodrich - Rear
Model - G-force TA - Rear
Size - Front 255/50-17, Rear 235/55/17
Steeda Sport Spring Kit
Rotor Pros drilled and slotted rotors
Wheels
Brand: Konig
Model: Beyond
Wheel Diameter: 18x8.5 18x9.5
Offset: 35mm f, 45mm r
Tires:
Brand: Nitto
Model: NT555
Size: 255/45-18 f, 295/45-18 r
Suspension Mods if any: none
Wheels / Tires
Wheels:
Brand - SSR
Model - GT-10
DIA. - 18 x 9 (f), 18 x 9.5 (r)
Offset - ??mm (f), 43mm (r)
No Spacers
Tires:
Brand - BFG
Model - G-Force KDW2
Size - 255/45-18 (f), 285/40-18 (r)
Suspension:Eibach Pro-System
Wheels:
Brand - SSR
Model - Comp light
DIA. - 18 x 8.5 (f), 18 x 9.5 (r)
Offset - 37mm (f), 42mm (r)
1. Wheels are very light probably the lightest on the market, potholes beware
2. Front center caps did not fit. I had to machine the inside a little, not a big problem but almost lost my center caps.
Tires:
Brand - BFG
Suspension:Full FRPP kit including springs, shocks/struts, swaybars, strut brace
lbc50 said:
Wheels:
Brand - SSR
Model - Comp light
Tires:
Brand - BFG
how much do they weigh?
your car looks hot by the way
love the spoiler delete... as my sig shows
j
Wheels:
Brand: Mustang Tuning (made by Verde I believe)
Model: Anthracite Deep Dish Bullitt
Wheel Diameter: 18"
Offset: (F)18x9 +36mm, (R)18x10 +45mm
Did you need/use a spacer? Yes, 1/4" on the front
Tires:
Brand: Nitto
Model: 555
Size: (F) 255/45/18, (R) 295/45/18
Eibach Pro springs, BMR LCA, BMR adjustable panhard rod
Wheels:
Brand - Ford front aftermarket rear
Model - Dark Grey painted Bullit (Bullitt Take-offs)
Wheel - Diameter Front 17x8, Rear 17x9
Offset - Front 99-04 stock, Rear 99-04 stock
Tires:
Brand - Kumho- Front
Model - Ecsta ASX
Brand - Kumho - Rear
Model - Ecsta ASX - Rear
Size - Front 245/45/17, Rear 275/40/17
Wheels:
Brand: Kazera
Model: KZA
Diameter: 18x9.5
Offset: 45mm
Did you need/use a spacer? no
Tires:
Brand: BFGoodrich
Model: KDW (Traditional Tread)
Wheels:
Brand: Niche
Model: F18 Black
Wheel Diameter: 20x8.5 and 20x10
Offset: not sure
Did you need/use a spacer? No, however the rears were taken to a wheel shop where they welded part of the inner hub to make it fit properly without hub-centric rings and then cut part of the hub off to get the offset/backspacing correct. Niche doesn't make the Black F18's in 20x10 for mustang yet.
Tires:
Brand: Nitto
Model: NT555 Extreme
Size: 245/35/20 in front and 275/35/20 in rear
Suspension Mods: Roush Springs at all 4 corners with no issues. (not pictured)
Sorry for the crappy pic, it's bad weather here.
