weight reduction
750chopperman
27
lafayette, IN
I am in the process of doing some weight reduction on my car. When I got the car it already had a fiberglass hood and aluminum heads, and drive shaft and it weighed 3,220. After what I've done so far it weighs 2,780. I am very impressed with the performance gain I've got so far and would like to continue. I ran a 14.3 @98mph the first time out and after the weight reduction, changing timing to 14 and removing the accessories I ran a 13.6 @103mph. Here's a list of what I've removed. What else can I remove and still have a street car? I still need to remove the quad shocks and my next step is lighter wheels and tires and cutting out the crash beams, and tubular front. Im sure there is more than whats listed this is just everything I could think of. Who has the lightest hatch out there?
Heater core and all vents
Dash frame
all sound deading
all insulation
spare tire and jack
gutted rear seats
a/c
smog pump and related parts
power steering
sway bar
lumbar motors from seats
cruise
inner fenders
windshiled wipers and fluid resivoir
inner front bumper and supports
charcoal canister
radio and speakers
all uneeded wiring
horns
rear hatch cover
floor mats
all associated bracket, nuts, and bolts Probably five pounds in just nuts and bolts
My 82, an original non ac car, still has the heater, alum bumpers, stock front seats, and scaled 2705 with ten hole wheels. I plan some more removals, some from your list. Things like the inner fenders, hatch trim, headliner, and some under dash stuff are going, as are the power brakes.
If I make it a track only car, all the heater stuff will go, the doors get gutted, and the bumpers will be lightened.
I hope to take out enough to offset the weight of the cage.
You can take so much off a fox and keep it looking decent. The plastic trim and all doesn't weight much at all. There is a ton of stuff that can be removed from an already light platform. 2600lbs is not hard to achieve at all. That's Civic weight right there. 260 horses on a 600lbs fox will make it run like a 400hp cobra. Here is a list on mine.
Complete Deletes (no replacements)
Front Bumper w/ Shocks
Fog Lamps w/ Lamp Support Bracket
Side moldings
Airbag System w/.Bracketing & Sensors
Hood Prop
Hood Latch Assembly w/ cable w/switch
Washer bottle
Evap Canister
Front Swaybar
P/S System
Smog System
A/C System
HVAC unit under dash
Stereo system w/speakers
Cruise Control System
Sound Insulation Material Deleted (from firewall to hatch)
Rear Seat w/all Bracketing and Belts
Sub-brackets on Dash Support Frame
Center Counsel Supports
Differential Dampener
Padding under carpet and hatch
Quad Shocks and Brackets
Spare tire and jack
Rear Bumper w/shocks
Quad Shocks w/brackets
Tailpipes
Brake Booster
Lightweight Replacements: (replaced with lighter components)
Aluminum Heads
Aluminum Pullies
Front Coil Over Conversion
Tubular K-Member
Tubular A-arms
Flaming River Manual Rack
Catless Mid-pipe
Aluminum Driveshaft
I dunno, man. I could only yank so much out of mine before I ran into the choice of whether I make the thing strictly a toy or something that I could actually stand driving for more than 10 minutes before going deaf, being roasted alive, or not having anywhere to rest my elbows. :)
Removing the bumpers and horn on a street car would seem like a very, very bad idea, as far as safety goes - kinda crossing the line from practical to race-only. My horn's saved me from careless idiots more times than I can count (especially when the old-fart snowbirds start flowing into town in autumn), and if that fails, I'd at least like to have a bit of steel between me and the idiot pulling a U-turn in front of me while I'm going 45+ mph...
Horns weight what? A pound or two tops? Bumpers, you might want to keep. Daily driver, hell no, but for occasions, it's ok. I also have a truck and another car.
all i kno for a good 50 pounds is the a/c unit.. you'll need a shorter belt for the skip... if its only for drag racing take the power steering out too.. im not sure the name of it but there is somthing in between the front bumper and radiator that adds weight and you dont need it a guy told me the other night but i think he was a crack-head.. i had the hood poped and he walks up tellen me to rip all this stuff out to make it lighter i was just tryen to fix an oil leak.. lol must have been on somthing~!
I was wondering about the hood too? How much does the latch weigh? I dont mind using hood pins, hell it may fix my hood gap problem lol. Im going to get my car weighed next time I go to the track. Im hoping to be in the 2000's, Ill be happy with 2999.
I've got the following removed: How much do you think this dropped?
A/C Delete
Smog delete
Fog lights + brackets
Alum. driveshaft
Spare tire + jack
Evap/Charcoal
Hood liner
No tailpipes (dumps)
93 cobra bumper (lighter?)
Weight added:
SF Connectors
MM Strut Brace
DEFWISH said:
is it true that just switching to aluminum heads saves like fourty pounds?
Have you ever picked up stock heads? They weigh about 50-60 pounds each. I have a set of gt40p heads waiting to go in my car, I can bearly pick them up to move them anywhere, mostly because you cant get a good grip on them, but once you do get a grip you better put them where you want them fast cause they are HEAVY. Im gonna need another person there to help me put those things on the car haha, im not going to be able to position them myself. You could probably hold a set of aluminum heads with one arm.
