xoxbxfx
What is the reason for going to an electric fuel pump? The requirements for your engine are well within the abilities of a mechanical fuel pump, unless fuel injection is in your near future? Mechanical pumps are reliable, cheaper, quieter and easier to plumb. If you do decide to go electric, you may want to research how loud the pump is before buying. Some of these things sound like small air compressors when they are running. My 2 cents ;-)
of course there is a reason... its a PITA
I Agree though, a mech pump is much easier and can flow what he wants.
Nothing that's been suggested here in an electric pump system could or should be called a "Doo-Dad"
Even with a low pressure pump, you still need a regulator, run it without one and you'll likely have problems. With a carb, the fuel pressure is only there to push down the float in the fuel bowl to lift the needle off the seat,and let fuel flow into the bowl(s) it takes very little pressure to accomplish this function. Too much pressure and you flood the carb, eventually dumping fuel either into the carb throats (marine carbs are designed to do this) or all over the top of the engine.
Fuel pump also quits pumping do to the lack of force driving the pump lever (commonly called a fuel pump eccentric mounted on the front of thecamshaft):SNSign:
