I asked my shop to check for coil bind and they reported none though they didn't tell me how much space there was at max lift.
In looking at say:
http://www.rpmoutlet.com/musv8compcam.htm
I see that for the Stg 1 cams (the 262s, the ones I've got), they say "Valve springs
recommended" (emphasis mine.) Same with the 270s. For the 278s they say "Valve spring upgraded
required". I presume that the requirement on the 278s comes from more aggressive ramps since the gross lift is the same for all 3 cams (0.550")
If the lift was the cause of the "requirement" on the 278s, it would apply to the 262s as well but for that, and the 270s, they only "recommend" a spring upgrade.
Sean Hyland also uses stock springs up to 0.550", so I've read. Whatever you think of the guy, he's been doing these things for a while now and if he's willing to use them, I should be okay...
